SETTING DIM LEADER ARROW SIZE
jbaldeo
9,500 次查看
10 条回复
1 条消息(共 11 条)
jbaldeo
can anyone tell me how to permanently set qleader arrow head size from .042 to .07. Everytime I exit autocad 2014 I lose my settings to the original .042.
0 个赞
已接受的解答 (1)
9,501 次查看
10 条回复
回复 (10)
2 条消息(共 11 条)
rkmcswain
As far as I know, QLEADER arrowhead size is determined by the current DIMSTYLE, or more specifically, the value of DIMASZ.
Set this in your template or existing drawing(s).
0 个赞
3 条消息(共 11 条)
jbaldeo
It holds it in the drawing using dimasz, but if I exit autocad completely and go back into the same drawing it resets to 0.042.
0 个赞
4 条消息(共 11 条)
pendean
Community Legend
Community Legend
DIMASZ is a per-drawing setting, and it doesn't change by itself: you most likely have a startup routine, created by someone in your office or by the person that set up your AutoCAD, or a favorite add-on you have. It is doing the changing for you.
DIMTSZ set to something other than zero does render DIMASZ useless.
May I ask: are you using Annotative dimstyles?
5 条消息(共 11 条)
jbaldeo
DIMTSZ is set to 0 and I tried the DIMASZ on different computers and these programs are "stand alone" but still get the same results (it resets). I am not using annotative dimstyles. Maybe I should edit the template itself? Do you know where it is normally located?
0 个赞
6 条消息(共 11 条)
nestly2
Did you try setting the Arrow size within the Dimstyle?
0 个赞
7 条消息(共 11 条)
jbaldeo
yes I did but when i exit and return to the drawing it resets
0 个赞
8 条消息(共 11 条)
nestly2
Attach a sample drawing containing at least one Qleader so we can confirm whether it's drawing related,  but I tend to agree with Dean that there's likely a startup routine/lisp that's setting the value for each drawing loaded.
0 个赞
9 条消息(共 11 条)
rkmcswain
After your drawing initializes, run the "U" command until it says "Everything has been undone"
See if DIMASZ is what you previously saved it as.
0 个赞
10 条消息(共 11 条)
不适用
Changing the DIMASZ only changes the arrow size on dimensions. It does not change the arrow size on a leader. I am running 2018 and cannot find out how to change the arrow size on a leader. Can anyone help?
0 个赞
11 条消息(共 11 条)
peterm
已接受的解答
In which case you need to edit the leader style _mleaderstyle
0 个赞
