Hello ,
I hope this is not to silly of a question and I have searched for a couple of days for the answer to my problem before posting. I can not get my dimension to snap next to my object. In other words I will snap a dimension to an object in front view and it will be the correct dimension but when I look at it any other view ( SW ISO ) the dimension though correct is a few feet away from the object. I have found that it is staying to 0 on the Y axis. I am snapping the dimensions using OSNAP but still it appears away from the object. Is there a way to keep my dimension in the same linear plane as my object. I have also found that moving my object to 0,0,0 will put my dimension where I want but would rather figure out how to move my dimension next to my object without having to do it manually ( grab and drag lol ) I have attached a picture for reference.
Thank you
Jeff
