Set dimension arrowhead size in dimension style manager.
No aplicable
No matter what size I set it at, the arrowhead is microscopic. I have changed the overall dimension to 48.000, or to 1, it is the same size. I didn't have this problem in AutoCAD 2013.
0 Me gusta
Responder
Soluciones aceptadas (1)
3.907 Vistas
22 Respuestas
Respuestas (22)
Patchy
Check this:
0 Me gusta
No aplicable
It is checked already.
0 Me gusta
Patchy
Attach your drawing and see.
0 Me gusta
Patchy
Check the setting, Unchecked ☺
0 Me gusta
No aplicable
Exactly the same when unchecked
0 Me gusta
beyoungjr
How many dimstyles do you have and are you sure you are changing the one that is used for your target items?
Blaine Young
Senior Engineering Technician, US Army
0 Me gusta
beyoungjr
Also, any text style bugs?
Blaine Young
0 Me gusta
No aplicable
I only have one dimstyle, standard. And yes, the text is wrong, too. It is supposed to be Romans, 9" tall. it is also microscopic, and not Romans.
0 Me gusta
Patchy
Maybe you're using inch & feet dimstyle in the metric based drawing.
0 Me gusta
No aplicable
No, inch and feet drawing.
0 Me gusta
Patchy
Let's see this drawing.
0 Me gusta
No aplicable
This is one of my dwt's. I just got upgraded from 2013 to 2019. I imported all of my settings.
0 Me gusta
Patchy
It is not too small, it's too BIG
0 Me gusta
No aplicable
Well, here, it is microscopic. I have to zoom in real tight on the end of the line to see it. I have done a zoom all numerous times. Never saw that.
0 Me gusta
Patchy
Zoom out , really far away and use command Leader and see.
0 Me gusta
No aplicable
Well, it looks like I went from one problem to another. Until this time, it was always so teeny tiny, it just looked like a line. the text was so teeny tiny too. Ok, how do I fix this then?
0 Me gusta
Patchy
Model space is too big
Draw it 1:1
0 Me gusta
No aplicable
If I use MLD mleader, the arrow seems to be good. Why would there be such disparity between the two commands? (I just want the arrow and line, don't do a lot of dimensioning, thankfully)I guess I need to go back and change all my settings in dimension style setup. I will just copy what I had in 13 again, but that wasn't working right, before. (It did work in 13, just not in 19.)
0 Me gusta
beyoungjr
Multileaders have their own style manager.  The adjustments in Multileader styles should not end up fixing a problem in Dim Styles.
Blaine Young
0 Me gusta
