Set default Plotter
Set default Plotter
ace_guru
Message 1 of 10
Set default Plotter
ace_guru
Greetings all,
This may be a silly question, but when sending a drawing to a client, how do you set the default plotter to be something else? I know you can set the default plotter to none if you use etransmit. Not sure if you can do this any other way.
Client wants all his drawings to be set as the following; "Default plotter set as "Default Windows System Printer"".
Never seen anything like that before.
Cheers,
Replies (9)
Message 2 of 10
tmccar
Right-click on the Model tab (or Layout tab, as applicable) and click on "Page Setup Manager". Click "modify" and select the "Default Windows System Printer.pc3" option.
Message 3 of 10
imadHabash
i think that your client OR you can prepare page setup and that's it.:)
Imad Habash
Message 4 of 10
pendean
Community Legend
Community Legend
Set up (and save) your DWG files that way as noted here before you send them http://forums.autodesk.com/t5/autocad-2013-2014-2015-2016-2017/set-default-plotter/m-p/6243209#M1179...
Message 5 of 10
ace_guru
Folks,
Thank you all muchly for the quick response & solutions.
Tmccar, thanks & kudos to you my friend. Who knew it could have been that easy.
Cheers,
Message 6 of 10
tmccar
Glad to help, ace
Message 7 of 10
rrowe24N24
how do I set this as a default for current projects and any other project that I open?
Message 8 of 10
tmccar
If you save the page setup in the template file you're using, that should do it.
Message 9 of 10
rrowe24N24
so why is it I'm having to set the printer / plotter name every time I want to print.
I have this set as my default printer (SHOP 11X17)AUTOCAD PRINTING_issue_2-27-20.PNG in windows.
Message 10 of 10
pendean
Community Legend
Community Legend
AutoCAD PLOT parameters are saved in each tab of each DWG file independently of your system settings. 38+years so far, nothing has changed in 2020.
There is no such thing as a 'default printer' option in AutoCAD for all files you'll ever open unless you wish to customize a startup routine to go through and load up one of your preferred pagesetups.
