set a paper color
c_ly0745K37
set a paper color
c_ly0745K37
I am developing a card at the moment that would be used on phones at night.  I then want to give it a dark background color when exporting to PDF so as not to harm the eyes.
I tried to define a fill color that matched the size of my paper and put it in the background, but this solution is buggy.  Several layers disappear leaving me a pdf with only (or almost) only the fill color.
Do you have a solution?  I thank you warmly.
Replies (18)
imadHabash
Try HATCHTOBACK (Command) and see if any changes .
Imad Habash
c_ly0745K37
This is already a solution that I have tried without success.
imadHabash
We will give more help if you can attache here your CAD dwg file for testing .
Imad Habash
RSomppi
Try restricting the hatch so that none of it coincides with the other objects.
pendean
Community Legend
Community Legend
It is often not enough to send stuff back, you also have to bring stuff forward: explore all the many options in DRAWORDER command in AutoCAD's HELP, I'll get you started here
https://help.autodesk.com/view/ACD/2024/ENU/?guid=GUID-3DC76D6E-8F81-4803-8D0A-AA7541D6357E
c_ly0745K37
I don't really see how to do it, I'll send you the attached file
pendean
Community Legend
Community Legend
What is disappearing please? See attached PDFs from your files
wispoxy
The default PublishToWebsite PNG.pc3 driver Properties > Custom Properties > Background Color > Select Color, then convert PNG to PDF. You'll need to create some custom paper sizes for the PNG driver that convert inches to pixals though.
c_ly0745K37
Hinnn ??
How did you do that?  ha ha, when I export on my side, I get this
wispoxy
Ok that's funny šŸ¤£
pendean
Community Legend
Community Legend
@c_ly0745K37 wrote:
Hinnn ??
CAD file showing you "how" to follow along with the instructions above was posted, start there.
HTH
c_ly0745K37
What file are you referring to?
pendean
Community Legend
Community Legend
Scroll up to #8
c_ly0745K37
problem solved, I changed High Quality Print to DWG to PDF
pendean
Community Legend
Community Legend
Can you explain please? Your shared DWG file was already set to do that
wispoxy
If what you said is true, the problem wasn't with the .dwg it's your .pc3 file and it varies per user default changes. High Quality Print.pc3 and DWG to PDF.pc3 are mostly the same output settings especially the color by default unless you changed it. The default for paper color of both is white.
You didn't mention you changed the default driver settings for your DWG to PDF.pc3 local driver. Really it works with High Quality Print.pc3 too if you match the driver settings. šŸ˜“
c_ly0745K37
Yes, my file was set to high quality.  I changed it to DWG to PDF and there were no more presentation errors when exporting the document.
Yes, my paper remains white, it is the color of the hatching that I placed in the background which makes my paper color, for a document which will probably never be printed, but only consulted on the telephone.
Thank you for your help anyway.
wispoxy
I understand you used a hatch, but they should have been the same. Maybe redownload the default High Quality Print.pc3 or match the settings to DWG to PDF.pc3.
