Sending VIEWBASE to model space.
mark9LYXZ
mark9LYXZ
As part of my #D Model documenting workflow I regularly send VIEWBASE views from layout space to model space. When AutoCAD does this it sends all geometry to a raw autocad dwg file, which I then have to cut and paste into my own template file to allow further annotation. This is eating a lot of time.
I have my own template file set as QNEW and the template folder location set to suit.
I have located the standard autocad templates in the appdata/LOCAL folder and need to know which one AutoCAD opens by default when processing a 'Send to Model space' command so that I can replace it with my own template and rename to suit AutoCADs default preference.
I have tried editing the acad.dwt file (which I only assume is default) but this doesn't work.
Nothing in the folders tab of options points to a file or folder location that gives me a clue to the location of this file.
Can anyone she any light on this?
GrantsPirate
What method are you using to get the viewbase views into MS?
I use EXPORTLAYOUT when I want to do this and it seems to work.  Maybe that will work for you?  Without more information it is hard to give a definitive answer.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
