AutoCAD Forum
Selection window in AutoCAD
4 REPLIES 4
2463 Views, 4 Replies
when i click on a line the selection box comes up. how do i turn that off?
@Anonymous,
john.vellek has edited your subject line for clarity: selection
4 REPLIES 4
imadHabash
HI,
turn it off from the Selection Cycling button (see below image ) or type SELECTIONCYCLING in command line and change the value to zero.
Command: SELECTIONCYCLING
Enter new value for SELECTIONCYCLING <2>: 0
Good Luck..
Imad Habash
Kent1Cooper
If the image in Post 2 is what you're talking about, it means there is more than one thing there, which it may be worthwhile to know [and do something] about, if you are expecting only one thing.
Kent Cooper, AIA
john.vellek
Hi @Anonymous,
I hope that @imadHabash's quick solution helped and that you also consider @Kent1Cooper's suggestion about knowing when there are objects on top of each other. To remove such instances you might investigate the OVERKILL command.
John Vellek
john.vellek
Hi @Anonymous,
I am checking back to see if my post or others helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
Forma Design Contest
