Selection preview issue
CADmgrMike
Message 1 of 19
CADmgrMike
I have a user laptop that doesn't highlight objects when selected.
I have tried 2 separate Windows user profiles and both AutoCAD and C3D. Same issue on both.
I have checked every selection variable I can find. All are set like other pc's.
I also updated the video driver.
This would appear to be a Windows issue, but can't figure out where.
Any ideas, greatly appreciated.
Mike Porter
https://provostandpritchard.com/
Replies (18)
Message 2 of 19
paullimapa
Have you tried setting Gfxdx12 to 0 and if that fails run GraphicsConfig and turn off Hardware Acceleration?
Paul Li
IT Specialist
@The Office
Message 3 of 19
pendean
Community Legend
Community Legend
SELECTIONPREVIEW variable?
HIGHLIGHT variable?
SELECTIONEFFECT variable?
PRESELECTIONEFFECT variable?
PREVIEWFILTER variable?
COMMANDPREVIEW variable?
SELECTIONPREVIEWLIMIT variable?
What are the year versions for all of that software and OS please?
Are both AutoCAD programs updated fully? Simply installing them never updates them. ABOUT command is a god place to share what you find for versions.
TIA
Message 4 of 19
CADmgrMike
checked all of the above. same as my personal pc.
2023 software, fully updated.
Mike Porter
Message 5 of 19
CADmgrMike
Yes. Tried that.
Turning Hardware Acc OFF makes objects appear hidden when selected, but not highlighted.
Mike Porter
Message 6 of 19
paullimapa
Another question: Do you happen to use a high definition monitor?
Paul Li
IT Specialist
@The Office
Message 7 of 19
CADmgrMike
The issue remains even when I remote into the pc and the display is on my monitors.
Mike Porter
Message 8 of 19
paullimapa
so what is your AutoCAD version # and Operating System you're running it on?
Paul Li
IT Specialist
@The Office
Message 9 of 19
CADmgrMike
see previous post
Mike Porter
Message 10 of 19
paullimapa
Did you mention Windows OS version?
Paul Li
IT Specialist
@The Office
Message 11 of 19
CADmgrMike
Windows 10
Mike Porter
Message 12 of 19
pendean
Community Legend
Community Legend
If  GFXDX12 variable set to 0 (that's a zero) then restarting AutoCAD2023 (and even restarting the PC) did not fix it...
Also consider turning off LINESMOOTHING and LINEFADING variables.
Then start GRAPHICSCONFIG command and change the 2D Display Settings pulldown from "advanced mode" to one of the other choices.
Since you already tried turning off Hardware Acceleration as a last resort, then your next step is to start a support ticket through your subscription portal as explained here
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-find-my-sup...
Message 13 of 19
paullimapa
If you're adventurous, try downgrading in Windows the graphics driver.
Have you tried running AutoCAD in safemode?
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-launch-an-A...
How's about resetting to defaults:
https://resources.imaginit.com/support-blog/how-to-manually-reset-an-autocad-based-profile-back-to-d....
Paul Li
IT Specialist
@The Office
Message 14 of 19
CADmgrMike
I just updated the driver from an older version so I'm thinking that's not it.
I haven't tried resetting CAD.
I tried several different CAD profiles so that's not it.
I know how to reset the secondary installer so it's as if CAD has never been opened. I might try that.
thanks for the idea.
Mike Porter
Message 15 of 19
CADmgrMike
I remembered I also had 2019 and 2021 versions installed on the pc.
Opened those in both AutoCAD and C3D. Selected objects highlight as expected.
reset the secondary installer for 2023 and opened software again. Issue still persists.
I think that would eliminate Windows being the issue. I may have to reinstall.
Mike Porter
Message 16 of 19
paullimapa
Well with each version of AutoCAD there are different graphics card requirements. Perhaps jump all the way up to 2024 and give that a try?
Paul Li
IT Specialist
@The Office
Message 17 of 19
CADmgrMike
Jumping to 2024 isn't an option.
I have over 100 CAD users, and only 1 with this issue.
Mike Porter
Message 18 of 19
paullimapa
Then hopefully a reinstall solves it otherwise may have to clone another computer that works for that staff
Paul Li
IT Specialist
@The Office
Message 19 of 19
pendean
Community Legend
Community Legend
@CADmgrMike wrote:
....I have over 100 CAD users, and only 1 with this issue.
Time to reimage that one PC to match the other 99: it might not hurt to also create a new login for that one user too while you are at it. Best wishes.
