AutoCAD Forum
Selection Effect problem
6 REPLIES 6
gabriel_gwgdestec
492 Views, 6 Replies
I have a problem selecting objects in autocad. The lines and hatches when selected are not in light blue, only some points are highlighted. Can anyone help me to fix this?
6 REPLIES 6
RSomppi
in reply to: gabriel_gwgdestec
Have you checked the settings in options?
It's hard to tell, but it looks to me like the Circle does have the "neon glow" selection effect.  But it it really doesn't, check whether you have Hardware Acceleration turned on [GRAPHICSCONFIG command].  Help about the SELECTIONEFFECT System Variable will tell you that, when it's set to 1, the effect works only with Hardware Acceleration on.
Kent Cooper, AIA
cadffm
in reply to: RSomppi
Are you knowing setting for "circles only"?
I have a customer with the same graphic issue,
so I like to know how to solve it.
Sebastian
RSomppi
in reply to: cadffm
Only the ones in Options.
cadffm
Please post any new informations, not solutions only, if you have
Sebastian
@gabriel_gwgdestec ,
These suggestions may help:
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
AutoCAD Inside the Factory
