Selection Block
Selection Block
Selection Block
How do you get rid of this box, started when I updated to AutoCAD 2020.
Alfred.NESWADBA
disable system variable SELECTIONCYCLING.
(but keep in mind that this could help a lot)
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Where in the options can I find that, or is that in the CUI?
Alfred.NESWADBA
It's a system variable, you can simply type it into the command-line, then <ENTER> then set it to 0.
Alternative methods are using the icon in the lower statusline or <CTRL><W>
- alfred -
Alfred NESWADBA
Alfred.NESWADBA
as usual and just to add ... also the help works well >>>here<<< ;))
- alfred -
Alfred NESWADBA
cadffm
why not start the command or set it by setvar?
Take a look in your very cheap help [F1] - CLICK - Selection Cycling (Status Bar Button)
Sebastian
