Selecting all lines from same layer that have the same suffix
marius.lechtenboehmer
Message 1 of 11
I have contour lines (polylines) with a precision of 0.25m. So 1.00m, 1.25m, 1.5m, 1.75m, 2.00m, 2.25m etc. They are all on the same layer. I want to select all the lines that have the suffix .00m (1.00m, 2.00m, etc.). How do I do that?
Using the quickselect feature and writing "*.00" doesn't work.
Replies (10)
Message 2 of 11
DumR0
Do you mean polyline with line weight 0.25mm?
drop some .dwg
Message 3 of 11
No. All lines have an attribute names "height". I want to select all lines from the same layer that end with .00 on the attribute "height".
Message 4 of 11
DumR0
try find command, check boxes for atribut
Message 5 of 11
Doesn't work. The polylines are neither blocks nor text. In the screenshot it is the attribute "Erhebung".
Message 6 of 11
DumR0
Message 7 of 11
ВeekeeCZ
It's "Elevation" in English. And it cannot be done using built-in features.
If you post some sample dwg I could do some quick lisp.
Message 8 of 11
Here's a sample of the data. A lisp would be amazing!
I also have AutoCAD Map3D available but I guess that won't help me.
Message 9 of 11
ВeekeeCZ
I don't know MAP, but C3D will definitely helps since you can set styles that differentiate contours (eg by layer)
(defun c:SelectContoursbyElevation ( / m s r i e)
  (if (and (or (and (ssget "_I")
		    (sssetfirst nil)
		    (setq s (ssget "_P" '((0 . "LWPOLYLINE")))))
	       (setq s (ssget '((0 . "LWPOLYLINE")))))
	   (setq r (getreal "\nRemainder after division 1: "))
    (repeat (setq i (sslength s))
      (setq e (ssname s (setq i (1- i))))
      (if (not (equal (rem (cdr (assoc 38 (entget e))) 1) r 1e-9))
	(ssdel e s))))
  (sssetfirst nil s)
  (princ)
Message 10 of 11
That is awesome! Thanks a lot. Works like a charm.
Message 11 of 11
3wood
You can also try ELEVLAYER.
It puts objects at certain elevation to a specific layer. Then you can use layer filter to handle them in groups.
