Select one point in point cloud.
Hey! I need to get my X,Y,Z coordinates in autocad for one point but I cant select one specific point for example - point on the floor. Mabye someone of you know this issue and can help.
You could use object snaps to eg start drawing a line from the point you want, then LIST the line to get the coordinates. Not sure if you can directly list the coordinates from just one point in a cloud.
Help - object snaps in point clouds
Alfred.NESWADBA
If it's really a point-cloud, then use 3D-ObjectSnap for "point-cloud point" with command _ID
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
I got only x,y coordinates when I click to my floor - mabye you know how to get z axis?
On your screenshot, the coords show Z to be 0.0000
I've never seen somebody working without a command line before!
@Alfred.NESWADBA's suggestion of _ID command will return the X,Y,Z coordinates of the selected point to the command line.
Alfred.NESWADBA
You have not used command _ID and picked one point in the point-cloud using 3D-ObjectSnap.
- alfred -
Alfred NESWADBA
