Select Multiple Text Value
aidilfitriansyahhV7KXB
Hi All,
I have huge numbers of text. I want to select multiple selections based on its value. How to select multiple value of text at once? For example I want to select "AAA" dan "AAC" at same times.
Tried to use this but not working. Thanks
Kent1Cooper
This at the Command line should find those [untested -- not at a computer with AutoCAD at the moment], and select/highlight/grip all those in the current space:
(sssetfirst nil (ssget "_X" '((1 . "AAA,AAC"))))
You can put as many strings together with comma separators as you want.  And there are various wildcards that can tailor what you're looking for -- read about them in Help for the (wcmatch) AutoLisp function.
Kent Cooper, AIA
imadHabash
Click on below image to see how with QSELECT command and Wild-Card Characters >> Click << you can select multiple text value .
Imad Habash
Hi, Thank you! this is exactly what I want!
ВeekeeCZ
This setting of FILTER works.
Or simpler:
But there one more option yet unmentioned which I do like most if comes to text value searching. The FIND command:
