I'm looking for a tool or LISP that works like a cross between SELECTSIMILAR and QSELECT.
I really would like to select elements by layer.
Qselect is bulky, and requires me to scroll through my list of layers to find the one I want. There is no way to "match" an element to use as a filter with Qselect.
SelectSimilar is a one-click filter, but it will only select the same element TYPE, so if I select a polyline, but other elements of interest are lines and arcs, those won't be selected.
I want to be able to click on an element, and then select all other elements on that level regardless of type.
Is there a Qselect setting that will allow for an existing element to be chosen to set the properties? Is there a SelectSimilar setting that will disregard element type? Is there a LISP out there that will do this one thing?
Thank you.
