Select all not working (CTRL+A)
leonbruneau2918
leonbruneau2918
Select all not working (CTRL+A)?
Command: APPLOAD
PATH: C:\Program Files\Autodesk\AutoCAD 2019\Support\en-us
File: acad2019doc.lsp
Action: Load
Wanted to share.  😎
imadHabash
is it not selectin all or unknow command appeared in command line ? i'm afraid that you use a lisp that make this issue ? you may need to reset AUtoCAD to default settings . >> Click <<
Imad Habash
leonbruneau2918
I also had to add the path in "APPAUTOLOADER".
Not too sure what changed to cause this.
