Segments won't join
david.coriatt
Observer
Segments won't join
david.coriatt
Observer
Observer
The segments in the attached file don't want to join properly
I am designing parts that will be cut using CNC machine. However when placing the parts on the fictitious metal plate in the computer the lines detach themselves making it difficult to manage
Kent1Cooper
Things are not at the same elevation.  Viewed from the side [partial]:
Kent Cooper, AIA
AVCPlugins
To merge, your curves must be on the same plane and their normal must be directed in the same direction. You can project all curves onto a plane using standard tools or use the AVC Flat plugin.
But the best option would be to use special plugins designed to optimize contours for CNC: AVC OSL.
And if you initially created solids in the drawing, then you can learn contours for milling from them using contouring plugins, for example AVC NC Preparation.
Plugins for AutoCAD
A>V>C>
AppStore | Facebook | Twitter | YouTube | Blog
pendean
Community Legend
Community Legend
Look at your own DXF file from different angles to see the issue ( I added color for clarity)
And this may affect your CNC performance
HTH
dbroad
The following process works pretty well for me.
  • Qselect by excluding 3d solids from selection set.
  • Copy(or move) whatever is still selected 100 units up(y direction).
  • Qselect points (window around new or moved objects) and delete them.
  • Qselect lines that have a zero length and delete them.
  • Run overkill on the objects.
  • Clean up all the garbage left by deleting obvious extraneous elements.
  • Run flatten on the remaining objects.
  • Run mpedit on the objects, using the join option.  I recommend using a 0.01 tolerance.
Architect, Registered NC, VA, SC, & GA.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
