Security Concern message
gdeep250
gdeep250
Community Visitor
Community Visitor
An executable file was found outside of the specified trusted locations. What do you want to do?
c:\program files\adobe\acrobat dc\pdfmaker\autocad\2015\64\acrobatacadic.dbx
Make sure that this file comes from a trusted source and does not contain malicious code.
cadffm
and your question is?
If you have installed pdfmaker and you want to use it in AutoCAD,
add the path as trusted path in
OPTIONS/FILES/.. trusted ..
Is the 3~5 node there
Sebastian
paullimapa
What brings up this alert window when you’re in AutoCAD?
Paul Li
IT Specialist
@The Office
pendean
Community Legend
Community Legend
May I ask why you are inquiring here about Acrobat files? Did you not install it? If you don't use it (an therefore don't trust it) since AutoCAD2015 was current you can always remove it.
This is your call my friend, not ours.
