SECTIONPLANETOBLOCK modify default section settings?
No aplicable
Hey All,
I hope that most of you are like me, staying healthy and still diligently working through our current crisis (from home). Just a brief question: Is there a way to define the default section properties in SECTIONPLANETOBLOCK so that I don't need to go in and change adjust them for every section line I add to my drawings? I find myself spending around a minute or so per section having to change hatch types, line styles and colors, and that adds up when I have a couple dozen sections to do. The only workaround I've found is to copy and paste my section lines after creating one.
Thoughts?
0 Me gusta
Responder
354 Vistas
1 Respuesta
Respuesta (1)
cheryl.buck
Autodesk Support
Autodesk Support
Hi @Anonymous,
I hope you are safe and well also!
There does not appear to be a way to save custom default settings for the SECTIONPLANETOBLOCK dialog, but I tested your workaround and it works great!
That's a really good question, I think that would be a great addition to the program, and encourage you to submit the idea through the Product Feedback link.
If a post was helpful, Likes are always welcome.
Please click the Accept Solution button for any posts that resolve the issue or answer your question.
All the best,
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider Liking the post.
0 Me gusta
