>> If VIEWBASE is truly superior, then why not discontinue SECTIONPLANE
Discontinuing functions is in most times not an option, especially as there might be a lot of applications, scripts, tools, ... are out in the world working with that tool.
It's my personal opinion, but I don't have a problem if other people like to use _SECTIONPLANE more than _VIEWBASE.
>> Why should I have to load up the entire 3D model just to look at a 2D section or view of it?
You can run command _EXPORTLAYOUT to save only 2D info's from your model
>> Perfect example is SECTIONPLANE.
Report all the bugs you seem to have found with this command to Autodesk (using your subscription center), it might be possible they find a ways to get it working (for this issue it's just me not finding a solution) or they can forward the case to the dev-team. (...ever done that?)
- alfred -
Alfred NESWADBA
www.ish-solutions.at ...
blog.ish-solutions.at ...
LinkedIn ...
CDay 2025------------------------------------------------------------------------------------
(not an Autodesk consultant)
