Sectioning within the layout tabs
No aplicable
I am trying to create an engineering drawing for a 3D part. In order to dimension and label properly, I need to show appropriate details and sections. I am trying to figure out how to create sections within the layout tabs. The two photos below show what I am trying to achieve.
I tried to do this using a section plane inside model space, creating a block and inserting it into my layouts tab. However the scale was off and when I tried to fix it, it didn't work. I also tried to use the section button inside the layout tabs (that is after using the view--->base--->from model space and adding in the top and ISO view of my model). That did not work either.
Is it possible to create sections within the layout tabs and then be able to dimension them. In addition, in the picture above, there is a dual section (section A). I am also having a hard time figuring out how that was put in.
Thank you.
0 Me gusta
Responder
Soluciones aceptadas (1)
491 Vistas
4 Respuestas
Respuestas (4)
imadHabash
Solución aceptada
since you start to fix your issue , i encourage you to read and follow this AKN articles that may give a hint for you . >> Click <<  >> Click 1 <<   >> Click 2 <<
regards,
Imad Habash
Alfred.NESWADBA
Yes, and looking to your samples that would be my preferred way to get that done.
Please read through >>>that part of the help<<< (plus following links) which describes well the options you have to create sections and details.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
No aplicable
Thank you!
0 Me gusta
No aplicable
Thank you!
0 Me gusta
