SECTION VIEW IS NOT SECTIONING
douglas_bauer
douglas_bauer
I am trying to create a section view to show the inside configuration of this assembly.  Sectioning from top to bottom, thru the center of the upper cylinder ram pin.  I will not work correctly.  Only shows the projection view.  I read and tried a lot of the things I understood from the forum but I cant get it to work.  It has worked on other assemblies but this one is a no-go.  Help is greatly appreciated!  Attached is a model, everything is a wblock that was inserted in this assembly.
btw  i am using v2024.1.2
TheCADnoob
Lots of content missing from this file
CADnoob
douglas_bauer
Thank you i see that now.  I am working on rebuilding the assembly and seeing where it goes from there.
wish me luck
Doug
