Second Move of Leader Jumping
No aplicable
When I move the contents of a leader once it moves to the correct location. But, if I stay clicked on that leader and try to move the contents of that leader a second time it seems to jump double to distance of what I want it to. Any thoughts on how to correct this jump? I have tried to adjust the snap settings but no luck.
Hopefully this all makes sense.
Thanks!
0 Me gusta
Responder
477 Vistas
4 Respuestas
Respuestas (4)
s.borello
If you turn all osnaps off do you get the same results?  I bet it's a snap issue.
0 Me gusta
No aplicable
I tried that, no luck though. I don't seem to have the issue with just multileaders, it seems to be an issue with smart leaders (ones that adjust their properties to the location you moved).
0 Me gusta
Alfred.NESWADBA
please let us know which type and version of AutoCAD you are using, best would be to start command _ABOUT and show us a screenshot from that dialog.
Also upload a new dwg-file with
  • a leader object created without movement
  • a copy of the above and one movement (to the right, one unit)
  • a copy of the first object and two movements (to the right, two times with each one unit)
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
0 Me gusta
BrianBenton
What are you referring to by "smart leaders"?
Brian C. Benton
bbenton@cad-a-blog.com
http://CAD-a-Blog.com
twitter.com/bcbenton
www.facebook.com/CADaBlog
0 Me gusta
