Script Issues
Script Issues
bsanada
Message 1 of 11
Script Issues
bsanada
I have recently run into a couple issues using scripts.  The first is I am unable to drag and drop scripts into AutoCAD.  I believe this started after upgrading to Windows 10.  If I use a macro to run the script it runs fine, but it doesn't run if I try to drag and drop it.
The second issue is I cannot set the default program for a .scr file to open in notepad.  I have tried going to "Control Panel\All Control Panel Items\Default Programs\Set Associations" and setting the default program for .scr files to notepad, but the settings won't change.  I also attempted to right click a .scr file to choose "open with", but "open with" is not an option for that type of file.  If I open notepad and browse to the .scr file it will open fine.
Brad
Replies (10)
Message 2 of 11
TheCADnoob
What version of CAD are you running?
I just tested the drag drop on windows 10 CAD 2017 and it works ok.
Is it all script files you are having problems with or just one?
As far as the default program see the screencast.
CADnoob
Message 3 of 11
pendean
Community Legend
Community Legend
Start SCRIPT command, navigate and select your scripts: do they work?
What version of AutoCAD are you using?
Post your scripts here or share their content, let's see the code.
Message 4 of 11
bsanada
I am using AutoCAD 2016.  It is probably worth noting that I have updated windows 10 to the "Anniversary Update".  I expect this may have something to do with the inability to set notepad as the default program for .scr files.  I have just checked another computer with this update and it has the same issue.  This is not true for the drag and drop issue.  Drag and drop works fine on the second computer.
This issue is with all scripts.
I have gone to the settings you show in the video and I can get to the point it lets you select notepad, but when you select notepad nothing changes.
Brad
Message 5 of 11
bsanada
Dean,
The scripts run fine using the script command.  They also work using a macro to call them and they work using AutoScript.  Below is an example script.
-layer m Cen c red l center
-layer m Hid c 8 l hidden
-layer m Hatch c 8 l continuous
SSX LT HIDDEN
CHPROP P LA HID C BYLAYER LT BYLAYER
CHPROP ALL LW BYLAYER
Brad
Message 6 of 11
pendean
Community Legend
Community Legend
Sadly, if it is that Win10 update then Autodesk has not fix yet. It is apparently surprising a lot of software developers.
I have my Win10 set up to hold all updates at the moment: hoping Autodesk has a patch before I'm forced to install it.
Message 7 of 11
john.vellek
Hi @bsanada,
I am not positive this is the answer as I don't have Windows 10 in front of me but I suspect it might not hurt to try. I am thinking that perhaps the SCR file is associated with Windows as a screensaver.  Check this AKN Article to see if it helps.
John Vellek
Message 8 of 11
bsanada
I did look at that article and my registry settings do match what they tell you to change it to.  I tried Microsoft support as well and they were no help.
Thanks for trying,
Brad
Message 9 of 11
john.vellek
Hi @bsanada,
I'm sorry that didn't help.
Have you considered rolling back the Windows Anniversary update?
John Vellek
Message 10 of 11
TheCADnoob
are you running as a user with administrator privileges?
CADnoob
Message 11 of 11
bsanada
Yes, I am running as an administrator.  I may have to look at rolling back that update.
Brad
