Script File for Block Insertion (Points) Won't Plot To Proper Coordinates
elyuzumaki
elyuzumaki
Hello! This is my first time posting in the AutoCAD forum and hoping someone could help me. I really can't figure this out.
I have a script file (.scr) that has all the points I want to show in the drawing. This file includes the name, x, y and z values of the points. When I execute the script command, the points plot successfully. The script uses a block for all the points. Some points would plot at the right coordinates but NOT all. I clearly don't get why it misses some points.. Is there a limit to a script file? Or is there a setting I must set before doing so? At first I thought maybe it's the coding from the excel file, before I paste it to notepad to create the .scr file.. or even redefining the  block when inserted in CAD.. I'm really clueless.
I read countless forum solutions but still can't find any.. If anyone could help me, I would greatly appreciate it. Please and thank you!
ВeekeeCZ
It seems to me that you need to turn off OSNAPS before you run the script. Use F3, or more systematically, tick this option...
cadffm
the current setting from the picture, not the red marked.
Or add it to your script:
Osnapcoord 1
Sebastian
elyuzumaki
Hello! Thank you very much! I figured it out this morning. I appreciate your response! It means everything. I’m sure it’ll help someone else. Cheers!! 😊
