Scrip file not loading into AutoCAD
sherardp
Message 1 of 14
sherardp
Using the "script" command to load a xxx.eq.scr file (see below) it does not load the function into AutoCAD and no plot is generated. I've made sure all blank spaces have been removed. Nothing has worked.
Here is my script file:
Pline
0.0,-0.000115129
0.01,-0.046051702
0.02,-0.07824046
0.03,-0.105196737
0.04,-0.128755033
0.05,-0.149786614
0.06,-0.168804643
0.07,-0.186148203
0.08,-0.202058292
0.09,-0.216715105
0.1,-0.230258509
Replies (13)
Message 2 of 14
paullimapa
I assume when you state that no plot is generated you mean no Pline is generated?
Paul Li
IT Specialist
@The Office
Message 3 of 14
sherardp
Yes, the .eq.scr file is supposed to draw a pline with the x,y coordinates shown in the file. It is not doing that when I use the "script" command in AutoCAD. Instead, it is asking for another point for input as if it never sees the .eq.scr file. Thanks.
Message 4 of 14
paullimapa
Worked for me but I did have to make 2 adjustments after copy+pasting from your posting (attached zip):
1. There was an extra empty line after the first set of coordinates which I removed:
2. At the end of file I added extra Return & Zoom Extents
Paul Li
IT Specialist
@The Office
Message 5 of 14
sherardp
I'm not sure what you mean by "Return & Zoom Extents". Did you add "Z Zoom" on the last line?
Message 6 of 14
paullimapa
I actually typed Z which runs the Zoom command. But if you open the zip file that contains the modified script file I attached in the previous post you’ll see what I added at the end
Paul Li
IT Specialist
@The Office
Message 7 of 14
sherardp
Sorry, I don't see a zip file attached.
But:
I checked that my script has no blank lines and added Z on the last line and I keep geting the error:
command 0.0,-0.000115129 unknown command "0.0,-0.000115129". These are the first numbers in the eq.scr file.
Message 8 of 14
paullimapa
I attached it this time...look back at my original reply post. That modified script worked for me.
Paul Li
IT Specialist
@The Office
Message 9 of 14
sherardp
Sorry, I still do not see an attachment. I've attached a screen shot of what I see in your reply.
Message 10 of 14
Pointdump
Hi Paul,
This is what happens when I try to download your file:
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Message 11 of 14
paullimapa
That’s because your antivirus program detects a .scr file and thinks that is a virus since it contains a series of commands. But this file type is also used by AutoCAD to run a series of commands as well. See if you can temporarily disable that to allow the download
Paul Li
IT Specialist
@The Office
Message 12 of 14
paullimapa
I renamed the file extension to .txt and attached it here.
After you download rename it back to .scr
Paul Li
IT Specialist
@The Office
Message 13 of 14
Pointdump
Hi Paul,
Works nicely. Thanks.
Dave
Dave Stoll
Las Vegas, Nevada
Message 14 of 14
paullimapa
Another thing I changed in the script is by preceding the Pline command with _.  The _ (underscore) invokes the native language command which is the English command and the . (period) invokes the original command incase it was undefined. So these are the main differences between your original script file vs my modified version. Glad that now it’s working out for you….cheers!!!
Paul Li
IT Specialist
@The Office
