Screen glitches seen recently.
No aplicable
0 Me gusta
Responder
Soluciones aceptadas (1)
5.114 Vistas
14 Respuestas
Respuestas (14)
imadHabash
i suggest to turn OFF hardware acceleration from GRAPHICSCONFIG command , any changes ?
Imad Habash
0 Me gusta
No aplicable
I had Graphics Acceleration ON since i have been using Auto Cad, but never have i seen such an issue.
Do you know why it is occurring all of a sudden?
0 Me gusta
vinodkl
Try restarting your system and see if the problem goes away.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
0 Me gusta
No aplicable
I have tried it many times since the problem begun, but no effects seen, same problem faced.
0 Me gusta
vinodkl
Can you post the screenshot of the 3DCONFIG and ABOUT. which tell us about the graphic card in use and the AutoCAD version you are using. Did you update the graphic card drivers recently? Cause I did see this the same thing happening with the other user after updating the graphics card driver.
0 Me gusta
No aplicable
Yes i did recently update my graphic card drivers.
0 Me gusta
nrz13
I get glitches like this routinely in AutoCAD 2020 (and in AutoCAD 2021).  I never encountered them before that point.  Reducing my graphics quality makes other problems worse on my system, so that's not a workable solution for me.
I notice it the most in larger drawings with lots of hatches and wipeouts.
Work:  AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-8700K, 32GB RAM, Samsung 960 Pro SSD, AMD Radeon Pro WX 5100, 3 Dell Monitors (3840x2160)
Home: AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-11700, 64GB RAM, Samsung 980 Pro SSD, NVIDIA Quadro P2200, Dell Monitor (3840x2160)
0 Me gusta
vinodkl
Check if your graphic card is certified to be used with Autodesk from this link.
Also, try to uncheck the options one by one from the "GRAPHICS PERFORMANCE"(3DCONFIG) dialog box and apply the changes and see if it fixes the issue.
If all this doesn't work, then you need to roll back the graphic card drivers.
0 Me gusta
pendean
Community Legend
Community Legend
Uncheck the boxes on that pop-up, and if that does not help, turn off hardware acceleration then go look for an older driver that works well, or check at Autodesk's webpage for drivers. let us know.
0 Me gusta
No aplicable
Solución aceptada
Got the solution.
Since i have an NVIDIA GeForce GTX 1060 driver, i went to the NVIDIA Contol Panel and checked the PhysX Settings.
It was set to auto-select, meaning it will configure between normal CPU drivers and GTX 1060.
Also having selected Hardware Acceleration meant it needed good driver so i set my default Processing driver to GTX 1060 and now its working fine even with Hardware Acceleration ON.
Also having uninstalled the recent updated version to a version that worked fine earlier would have helped.
Thanks a lot for help guys!
@pendean @vinodkl @nrz13 @imadHabash
R_Tweed
In the physx section, did you change it to cpu or gtx from auto?
0 Me gusta
No aplicable
To GTX from Auto @R_Tweed
No aplicable
Tengo el mismo problema, yo tengo Nvidia GTX 1050, pero no se como encontrar el Physx, espero puedas ayudarme gracias.
0 Me gusta
No aplicable
E d g a r,
No hablo español pero voy a intentar ayudarte.
Siga los siguientes pasos:
1- Busque el Panel de control de Nvidia
2- Seleccione la opción para definir la configuración PhysX resaltada en azul mi pantalla
3- Después, cambia la selección automática para GeForce GTX 1060
Espero haberte ayudado!
