Scaling
Scaling
Message 1 of 14
Scaling
Sometimes I have drawings where I need to get dimensions to get a correct drawing. And usually there only outside dimensions, not inside. By that I mean general dimensions for a floor plan is normally what I get, not dimensions for the inside for rooms. How can I make sure I correctly scale the drawing so its correct? the whole scaling thing is a little confusing to me.
Replies (13)
Message 2 of 14
cadffm
You need to know the length of one object or the dist between to points..
Floorplans have doors, standard doors have standard sizes,
or Walls, windows. That is not a CAD questions, it is your knowledge, find the right.
Then use command SCALE, reference
http://help.autodesk.com/view/ACD/2019/ENU/?guid=GUID-AE6B4228-F742-4E29-A8C0-28F3FB43EFA2
Pick Startpoint, use option Reference, Pick Startpoint again and the second point of current distance, after that type in your wanted distance value for this.
Sebastian
Message 3 of 14
Thank you
Message 4 of 14
imadHabash
Then you have to fix your rooms to get normal dimensions. please don't scale your plan drawings ever and never .
i suggest to use Reference object from scale command to control enough your issue . >> Click <<  just draw a line that you you want to take as a reference then scale all of your elements depending on that line .
Imad Habash
Message 5 of 14
I need to show scales on my drawings though, for example ones like this:
1/4" = 1'-0"
1/8" = 1'-0"
So how do I make sure my drawings have the right scale, with little to no dimensions given to me?
Message 6 of 14
imadHabash
in AutoCAD ... we draw to 1:1 scale . the scale matter is a Plotting issue that you have previously prepared for it. you have to know the paper size and the final scale that you want to plot with . for that you have to fix all of your drafting problems and finish it then you can print out your guaranteed plan to any scale you need .
Imad Habash
Message 7 of 14
So What your saying is depending on the paper size, that depends the scale I need? so how do I figure out the scale with the paper size?
Message 8 of 14
imadHabash
of course ... usually the Paper size that you want to put your final data on it will enforce you to select a proper scale and vice versa .
it depends on from where you want to plot , is it from  Model space or Layout paper space ?
Imad Habash
Message 9 of 14
its on the layout paper space in autocad. that way I can get an accurate drawing printed out.
Message 10 of 14
imadHabash
it's doable as the follow :
  • insert ( attache ) your title sheet in the layout paper space .
  • make a Viewport over your inserted title sheet and at the specify place .
  • now click inside the VP and zoom ( extents ) .
  • Now and since we don't know your plan size and paper sheet size specify your needed scale from  Zoom >> Scale command . >> Click <<
Imad Habash
Message 11 of 14
So I do I put in a view port? the company has autocad LT 2010.
Message 12 of 14
imadHabash
it's NOT clear enough to understand . but if you're asknig on how to make a viewports then read this link and i hope it's help . >> Click <<
hhmmmm it's old enough !!
Good Luck ...
Imad Habash
Message 13 of 14
The link you gave me was for 2018 version and I know, the company wont update it for some reason so I'm stuck with the 2010 version.
Message 14 of 14
imadHabash
viewports are existing in AutoCAD from the past . SO please try it and get back again and tell us about your attempts . 🙂
Imad Habash
