- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hi everyone,
I'm having an issue with scaling lineweights when printing in AutoCAD 2022.
Context:
- My lineweights are defined by layers, not by a CTB file.
- I draw in A3 size in the model space, and everything prints correctly with the right lineweights (0.35 mm for dimensions).
- When I try to print the same drawing in A4 format by applying a scale in the print setup (e.g., 1:1.414 to scale from A3 to A4), the lineweights do not scale down. The option "Scale lineweights" is greyed out and unavailable.
- I’ve tried using different CTB files, plotters, and printers, but the issue remains.
My question:
Is there a way to scale lineweights defined by layers when printing? If so, how can I activate this option or work around this issue?
Thanks in advance for your suggestions!
¡Resuelto! Ir a solución.
