Scaling in one direction onlly?
russel
Message 1 of 10
russel
using autocad 2018.  im in paper space and I want to scale up my object but I only want to scale it in the Y or vertical direction.  how do I scale my object without scaling it in both directions?  thanks.
Replies (9)
Message 2 of 10
Jay_B
The STRETCH command may work, what object type do you wish to scale?
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Message 3 of 10
russel
I just want to scale up some line segments in order to see them more clearly.
Message 4 of 10
imadHabash
>> how do I scale my object without scaling it in both directions? <<
either you insert your elements as block or xref and while the procedure play with X , Y factors as your need .
Imad Habash
Message 5 of 10
Jay_B
Sounds like the EXTEND command, using the FENCE option may work.
C3D 2018.1
C3D 2016 SP4
Message 6 of 10
russel
what I ended up having to do was to turn my object into a W-Block and insert the object and change the scaling along the Y.  thanks.
Message 7 of 10
russel
it was a little more work than I wanted to do but it did the job.
Message 8 of 10
Kent1Cooper
There are routines out there that will automate that for you, for instance this one.  I think that one does it by Block rather than Wblock, but the concept is essentially the same.  Some Searching will probably find others.
Kent Cooper, AIA
Message 9 of 10
scot-65
Kent's answer is the best:
command BLOCK.
Occasionally I will take a lattice hatch pattern and Copy-clip/Paste the
hatch as a unnamed block, then play with the x-scale to be 0.707
(first "flatten" the hatch field).
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
Message 10 of 10
This is so AWESOME!!!!!!!! Thank you a million times! Thank you. You are my new best friend!!
