Scaling in Autocad
Scaling in Autocad
No aplicable
I have made a design A in autocad as shown in attached image in a rectangular box.
Now I want to modify the design A to suit in the box shown as Design B.
I don't want to redraw it but just want to modify it using scale option so that the Design A will be fit into Design B box.
I have used scaling options but not in this kind of a situation. Here in one direction my dimension is increasing and in another direction my dimension is reducing.
So is there a possibility to use scale command in which one direction will have to be scaled up and another direction to be scaled down?
Thanks in advance..
Rajiv.
0 Me gusta
Responder
Soluciones aceptadas (1)
677 Vistas
5 Respuestas
Respuestas (5)
Alfred.NESWADBA
Solución aceptada
No, not with the command _SCALE.
But you can create a block from Design A, then insert that block and for the block-insertion you can set it's Scale-X and Scale-Y independently.
HTH, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
0 Me gusta
imadHabash
Since you have a very simple shape and to avoid any distortion issues i suggest to redraw new cases.
Imad Habash
0 Me gusta
No aplicable
Dear Mr. forums2rajiv
I guess you can also use dynamic block facility were you can view your objects as per your requirements..
Hope this could help you out...
Regards
DMC
0 Me gusta
No aplicable
Alfred,
Worked as I expected.. But I think when I do the same thing with large scale ratio the shapes can be distorted which we can't avoid in any ways.
So when I have a large difference in the boxes it's always good to redraw.
0 Me gusta
No aplicable
Thank you all for suggestions.
0 Me gusta
