Scaling a Scanned Map in Autocad
celticsfan
Message 1 of 8
celticsfan
Hi Folks
Just joined so my first post 🙂
Im working on a project for myself.. I have an 2 OS Maps at a scale of 1:1000 and 1:2500... I have scanned these,they are a4 and a3 in size respectively.... for the purposes of my site plan I need to trace around these to show neigbouring land/properties... for the life of me,I cannot get these maps at a 1:1 scale in autocad so they will match my metric setup (using mm)
Can anyone advise,I know using this method may not be perfectly accurate but it will suffice for the time being for planning purposes..
Any help appreciated
Ste
Replies (7)
Message 2 of 8
Patchy
Draw a reference line on the scanned image, find a proper distance on the map and scale the line and the map, then check the distance of the line.
Message 3 of 8
celticsfan
Thanks for the swift reply Patchy 🙂
There are no distances marked on the maps themselves...just at the bottom of it,the ''scale legend'' which goes from 0 up to 1000metres so I could take my scale ruler to that and it measures 1000m using 1:1000scale
Message 4 of 8
Patchy
Attach your map image here, let's find a reference point (Maybe)
Message 5 of 8
celticsfan
I cant attach the image here patchy as its licenced by the mapping company that sells them... but here is a link to one that is identical to what I am using except the scale legend at the bottom of mine goes up to 1000meters instead of 100
here is the link,i just shortened it as it was quiet long..
http://tinyurl.com/oemvder
Message 6 of 8
Patchy
The coordinates are at the corners of the map, kind of hard to see, but you must use them.
See the drawing attached below.
Message 7 of 8
celticsfan
You Patchy sir are a legend 🙂 Im all sorted now,cant believe i never thought of that..But il use the fact im a novice as an excuse..
Thanks again bud
Message 8 of 8
Patchy
No problem, we all started there.
