I work for a Landscape Design Company, and I have the hardest time scaling Raster Images.Here is how I do it, so if there is a step I'm doing wrong, please point it out for me.
1. Immageattach command
2. locate image to be inserted
3. leave specify on screen, scale, checked
4. create image into a block
I already have a Model plan drawing in my opened file that I need to scale the image to.I will be getting my X & Y dimensions from the Model drawing.
5. I take a distance measurement from my Model drawing for the X axis, and a distance from the same point in the Image, then I divide the two dimensions.
6. Scale command, select Raster Image, specify base point, which I select the upper right corner of the Image
7. R for Reference
8. Type in the calc I got from step 5
9. Now I do the same for Y, but instead of using the scale command I take the calc and multiply it by the Y scale I have in the properties
10. I enter that # into the Y scale in properties
The Image is now scaled, I move the Image to a point in the Model, and send the Image to the back for an Underlay
Then I rotate the Image to align with the Model drawing, ......but the Image is never to scale with the Drawing.
Any Help is much appreciated.Thanks
