Anuncios
Scales
yan.aquino
Scales
yan.aquino
Hello there I'm having trouble because when I choose my scale 1:50 and draw a line ( x length) and then switch the scale to 1:1 and draw the same line ( x length)  to see the difference the line is exactly the same does some know what might be happenning ?
0 Me gusta
Responder
340 Vistas
6 Respuestas
Respuestas (6)
john.vellek
Hi @yan.aquino,
Can you create a Screencast video of how you are working?  I thought you had this nailed down from your other thread but apparently you are still having some problems.  I am happy to help.
John Vellek
0 Me gusta
gotphish001
The scale in model space that I think you are changing is only the scale for how annotative objects appear in model space. It has no effect on line work, only things like text, dimensions, etc.  You should always just draw everything in model space at 1:1.
When you change the scale in a paperspace viewport that is when it changes the scale how you are expecting it to change in your above example.
Nick DiPietro
Cad Manager/Monkey
0 Me gusta
yan.aquino
Hello there thank you to the both of you for answering so quickly when I think that's the problem I had understand that the scale for the drawing was the three rulers that appear on the bottom right corner of the screen where the ortho command but now that you mention that, I'm wrong, right ?
0 Me gusta
john.vellek
Hi @yan.aquino,
When you draw in modelspace you should (best practice) draw at one-to-one.  This means if you need to draw an item one meter long then you draw it one meter long.
Paperspace layouts give you a view of that one-to-one model through viewports.
First, you need to make sure that you started your drawing off of a metric or imperial template depending on which you prefer.
If you picked the wrong one, don't worry. You change the drawing units by the use of DWGUNITS.
once you have constructed your 1:1 model, switch to paperspace and define a page setup. This configures the output size whether to a piece of paper or to a digital format such as PDF. Pick you r paper size and ideally the scale which should be 1:1.  I like to recommend always working 1:1.
So, the next step is to create viewport view of your model.  This is where you set up the relationship (scale) of the model size in real units to that of the piece of paper.
I like to teach my beginning users to use the zoom 1/xp method. This means 1 / scale x papersize (1:1).
The scale list lets you have this even easier but you can configure your scales to what you need.  It is merely a comparison of what you see in the paper (layout) versus what you are drawing in the model (drawing units).
If this is still confusing (and I can be confusing-my apologies), please attach a sample drawing of your model that is drawn in 1:1 and I can show you how to place it into a viewport with a variety of scales.
John Vellek
yan.aquino
Thanks so much will do, right now I'm on the car so I can't send the file but I will send it as fast as possible sorry is that I'm more of a visual learner so sorry for the troubles and thank you so much for taking the time to help. One more question how do I know that I'm drawing in inches or meters ? Is it when I set the scale to architectural or decimal ? Is that I have to use both systems
0 Me gusta
john.vellek
HI @yan.aquino,
Don't use units set but rather use -dwgunits.
If you like I can do a remote session with you.  If this sounds helpful, please send me a personal message (hover over my name on the left image) and let me know a good time, phone number and then we can get this to work for you.
John Vellek
0 Me gusta
