Scale problem with BricsCAD X AutoCAD
alfinmuharrram97
alfinmuharrram97
Hey everyone. I have a little problem here and really need your help. I have a couple drawing in BricsCAD with original scale (1:1). On the other hand, I have a same drawing in AutoCAD with original scale (1:1). The problem is, I try to copy the AutoCAD drawing to the BricsCAD but, the scale is not 1:1. However, the scale become small in BricsCAD. Hope you guys can guide me with this problem. Thanks in advance. in BricsCADin BricsCADin AutoCADin AutoCAD
0 Me gusta
Responder
Soluciones aceptadas (2)
809 Vistas
8 Respuestas
Respuestas (8)
cadffm
1. Make sure it is the same size.
   Use command DIST to measure a length in both
   Do you think they are drawn in same units?
2. Does it works the opposite way, from BCAD to ACAD?
    If so, check your BCAD InsunitsScaling setting
Sebastian
alfinmuharrram97
Thank you for your reply. I've already check it and I'm 100% sure it has the same size with both drawing. If I use this "InsunitsScaling" command, what should i do next?
0 Me gusta
cadffm
So the opposite way works, from BCAD to ACAD?
Okay,
if you are not familiar with a feature/command/sysvar, learn more about it, press [F1]
But this help is a bit confused, so remember the current value (1 ?) and try to use value 0 (means off)
Sebastian
0 Me gusta
cadffm
You are talking about clipboard action (ctrl+c/ctrl+v), or?
If not, tell us your way " try to copy "
and draw in line with length = 1 in Acad
how long is it after pasting in Bcad?
Sebastian
0 Me gusta
pendean
Community Legend
Community Legend
Solución aceptada
0 Me gusta
paullimapa
What if you xref the Briscad dwg into Autocad? Does the scale look right then?
Paul Li
IT Specialist
@The Office
0 Me gusta
Valentin-WSP
Solución aceptada
@alfinmuharrram97 ,
@alfinmuharrram97 wrote:
... The problem is, I try to copy the AutoCAD drawing to the BricsCAD but, the scale is not 1:1.
Might want to consider these links:
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
0 Me gusta
alfinmuharrram97
This method looks good. I tried it and it works. thanks...
0 Me gusta
