Announcements
scale map in AutoCAD to fit A4
Hi everybody
Can you tell anyone how could modify scale of map  I want on scale 1.1700.000 in layout,and how could i do for print this map in format A4
@Anonymous, john.vellek has edited your subject line for clarity: Scale
Replies (44)
Alfred.NESWADBA
why not following the suggestions in your other post >>>click<<<?
Create a scale and assign it to your viewport ...
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
Hi Alfred
In the model i have the real scale 1.1700.000 map  but i want make this scale on latout and more print on A4 on this scale
This the problem and could tell you for make on layout
Alfred.NESWADBA
Do I understand that correct that your model is not 1:1? If so then run command _SCALE (in modelspace), define a base point (the origin point used to scale) and then use the scalefactor 11700000 ... that should bring your model to have the correct (real) size in modelspace.
If my understanding is not correct that please show the data and explain it a bit more detailled.
- alfred -
Alfred NESWADBA
pendean
Community Legend
Community Legend
You need to draw at 1:1 scale in AutoCAD: fix that first, then follow the instructions given to you in your other post here https://forums.autodesk.com/t5/autocad-2013-2014-2015-2016-2017/scale/m-p/6407728#M131123
Otherwise just start PLOT command, select a 1:1 scale, window around your model, pick an A4 sheet, pray it will fit, and hope you never evern have to plot at any other scale ever again.
john.vellek
Hi tinigjeo,
The suggestions here are sound ones. It is always a good practice to draw your geometry at real scale 1:1.
So, if your model is not drawn this way, I suggest that you use Layer Property Manager to unlock, turn on, and thaw all your layers in your model. Then use SCALE and select ALL. You can apply your scale factor to get everything into real world dimensions.
Then you can use a layout in paperspace to create a viewport of your model. This allows you to zoom in or out to the appropriate scale.
If you need additional assistance or resources for any of these steps please update your post. If you want to attach your drawing, I can use it to make a video of the steps for you.
Please select the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
Hi John I will send you my map that i want pass on layout with scale 1:1700.000 and print on letter A4 on this scale Could you help me ?
john.vellek
Hi @Anonymous,
I am happy to take a look for you. Please attach your file.
John Vellek
FILE CAD
COULD YOU HELP TO ATTACH MY DWG MAP
john.vellek
@Anonymous, I sent you a private message for some directions to get the file to me.
John Vellek
Discussion_Admin
Can you add the eror you are getting and what browser you are using?
Also please make sure you are not blocking scripts from Lithium.com, Autodesk or Addthis.com ( s7.addthis.com) they are need for all features to work.
also please make sure you are using the latest releases of the supported browsers below (with JavaScript enabled😞
Chrome
Firefox
Internet Explorer 8*, 9, 10 or 11
Safari
Microsoft Edge
For a consistent and reliable mobile device browsing experience, we recommend using one of the latest popular mobile operating systems and devices with their default browsers (with JavaScript enabled):
iOS with Safari
Android with Android browser
Opera Mini
Blackberry Browser
*Note: Internet Explorer 8 is no longer supported on the Community after 7/23/2015, IE 8 users may have a degraded experience. Users with IE 8 on Windows XP may not be able to connect at all to the community
Discussion_Admin
I DONT HAVE ANY BLOCK BUT WHICH THE FOR FOR ATTACH THE FILE DWG
john.vellek
Hi @Anonymous,
  • I opened your file and first looked at paper space and saw that your units were set to inches which will not work easily as the map is in Kilometers.
  • -DWGUNITS was used to set your drawing units to meters.
  • Next, I measured a known distance (scale bar at 20 KM) and saw that it did not match the scale appropriately as everything in model space should be drawn at 1:1
  • I scaled your entire drawing up so that it measured 20000m.
  • Next, I selected layout 2 and started Page Setup Manager.
  • Created a new page setup that uses the AutoCAD PDF driver
  • I assigned the monochrome plot style, A4 paper in portrait mode, and scale is set to 1:1.
  • I assigned the page setup to the layout and stretched the viewport to approximately the location where it would fit inside the plot margins.
  • Next I entered modelspace by double clicking in the viewport. I then selected a Custom scale.
  • This zoomed the map to the appropriate scale as you requested.
I have prepared a Screencast video that displays these steps and also attached my copy of your file.
Please let me know if you have questions on any of these steps.
John Vellek
john.vellek
Here is a second video which shows the -DWGUNITS and SCALE by reference part of the steps in my previous post.
I apologize for the little hiccups in my video as I keept getting pinged by other activity on my second monitor - I think you will be able to grasp the steps though.
John Vellek
Hi John Sorry for my later I have see your video with carefully for 2 day ,but i dont understand the number { scale Specify reference length < 13886.7798> ] which is the method of calculate?
Hi
I hope to get one choise
HI JOHN
I HOPE ONE CHOISE
john.vellek
Hi tinigjeo,
The original scale of the map was not a standard size but most likely was scaled to fit something randomly.
So, in my video I showed the bar scale which is supposed to be inserted at 1:1 so I had to assume that it was when it was created. I drew a line from 0 to 20 km marks.
Then I drew a line that was truly 20 km in length. I used scale reference and selected the first length and indicated that I wanted it to be the length of the 20 km line I drew.
If you prefer to do this on a calculator that can be done too. take the 20000m and divide by the length of the 0-20km distance on the bar scale. This is the amount you have to scale up the entire drawing to in order to get it drawn at 1:1
John Vellek
Hi john
I am sorry again For following  this  steps.Could you drawing on video  with number.1,2,3... ect and change colour example red  The steps that I ought follow for this  map
best regards
Tini
