SCALE Command Not Working
Message 1 of 11
I am trying to attach a google earth image and scale it.
Using the Scale command, I don't get accurate results. Here's how I'm trying to do it.
Attach the jpg
Start the scale command
Select the attached jpg and hit ENTER
Click the base point (one end of the scale bar in the jpg)
Select R for Reference and hit ENTER
Specify reference length (200) and hit ENTER
Then it asks me to specify a new length ... I must be messing up the sequence. What am I doing wrong?
Thanks.
Replies (10)
Message 2 of 11
GrantsPirate
You will need to know a distance of something on the map, like the length of a building.  Then for reference you point to the opposite ends of the building and then type in the actual distance.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
Message 3 of 11
Patchy
R for ref
pick end point and the other end point then the distance.
Message 4 of 11
Right. I have a distance. The image has a scale bar in it, so I know it's 200 feet.
I'm using the start of the scale bar as my reference point.
Message 5 of 11
Alfred.NESWADBA
you might try command _ALIGN, that gives you the choice to select transformation points and then it rotates AND scales the objects accordingly to the reference points.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 6 of 11
 I'm also unclear about what is meant by "base point". How do I determine that?
Message 7 of 11
Patchy
Scale bar is on the image so you have to draw a line on top of it so osnap can use it.
Select the line as reference.
Message 8 of 11
Alfred.NESWADBA
Create a new drawing, just one rectangle, now test command _SCALE and try different corners of that rectangle as basepoint and see how (into which direction) the size then changes 😉
- alfred -
Alfred NESWADBA
Message 9 of 11
rkmcswain
Eight replies and no video yet? Smiley Surprised
Follow along with this. I'm scaling the cyan rectangle to the corner of the green line. Not quite on top of the red rectangle.
R.K. McSwain     | CADpanacea | on twitter
Message 10 of 11
GrantsPirate
From another post but same idea.
GrantsPirate
EXPERT ELITE MEMBER
Message 11 of 11
Thanks, everyone!
