Scala disegno
Scala disegno
No aplicable
Ho fatto un disegno sullo spazio modello, scala 1:1 e come unità di misura metri. Una volta nel layout, scelto il formato del foglio (un A1), la mia finestra di layout in scala 1:1 è minuscola. Cosa sto sbagliando?
0 Me gusta
Responder
424 Vistas
8 Respuestas
Respuestas (8)
imadHabash
pick inside your VP then zoom ==> scale ==> 1xp.
Imad Habash
0 Me gusta
No aplicable
Non è in grado di predire il problema, ma provate a chiudere il file e aprire un altro file
0 Me gusta
john.vellek
Hi @Anonymous,
Once you switch to your layout, double-click in the viewport to enter modelspace. No you can zoom a window around your model to the approximate area you want to display. Then using the scale list in the bar at the bottom (right) you can set the scale you need. If you want full size, then select 1:1 as Imad suggests. If that does not fit you can then explore other scales such as 1:10, 1:20, 1:50, etc.
Please let me know if you require additional assistance with this issue. If you would like to attach your file to a post I can help you set the scale too.
John Vellek
0 Me gusta
Johanna_Esteban
Bon dia @ giulia.tintin,
Você pode corrigi-lo?
Johanna Esteban
Autodesk Expert Elite | Autodesk Certified Professional | AutoCAD Customer Council (Beta Tester for Windows & Mac)
¿Te ha parecido útil este post? ¡Dame Kudos! :cara_guiñando_un_ojo:
Si ha sido resuelta tu inquietud, selecciona 'Marcar como solución' para que otros usuarios la encuentren fácilmente.
0 Me gusta
No aplicable
Il tuo formato é un block?
In caso di serlo , prova "insunits" da 1 a 4 o da 1 a 6.
Questo controlla la unitá dal disegno
0 Me gusta
john.vellek
Hi @Anonymous,
Has your issue been resolved with the help of the Community? If not, can you attach your file to a post so I can take a quick look?
John Vellek
0 Me gusta
No aplicable
Hi john vellek
Thank you for your reply.
The scale is 1:1 both in the modelspace and the layout window. Yet my
drawing is extremely small
0 Me gusta
john.vellek
Hi @Anonymous,
Can you attach your file to a post? Or, if it needs to remain private can you share it via a cloud location or send it to me?
John Vellek
0 Me gusta
