Anuncios
Saving DXF file with entities
No aplicable
Some of my dxf files are being saved without any entities. If I convert to json format and open them up in text editor and scroll to entities I find entities is open as such:
"entities": []
Has anyone dealt with a situation like this? This may not be a common issue but I will appreciate any help or guidance.
Andre Vega
0 Me gusta
Responder
1.057 Vistas
9 Respuestas
Respuestas (9)
john.vellek
Hi @Anonymous,
I have not seen this issue before. Do you receive any kind of error when you do the dxf creation?
Can you walk me through your process and also include both a drawing file and the DXF that you create from it?  I would like to see this first hand in order to give you some assistance.
John Vellek
0 Me gusta
john.vellek
HI @Anonymous,
I haven't seen an update from you so I am optimistically hoping that means you resolved your issue. Please update your post with your status so I can continue to assist you if necessary.
John Vellek
0 Me gusta
No aplicable
I have found that entities for a dxf file are generated when dxf file contains simple geometry such as lines and circles. I will attach two files, one with entities and one without due to it being made of a solid rather than lines. I will now like to know how can I read 3DSOLID, SOLID, or MESH information (point corners, direction, etc) from a dxf file?
I am using an open source parser to better read the dxf files: https://github.com/gdsestimating/dxf-parser
0 Me gusta
john.vellek
Hi @Anonymous,
I am trying to better understand what you are trying to do.
In one DXF file you show a sphere that has been exploded into 3dlines. In the other dxf file you show the same sphere as a 3d mesh.
I am uncertain what you are trying to get from one or the other file. What are you trying to do with the DXF file information?
Please give me some more detail so I can try to assist you.
John Vellek
0 Me gusta
pendean
Community Legend
Community Legend
>>>...If I convert to json format...<<<
Does that format support the object types your DXF file contain? That's usually what stops a conversion from working.
You probably need to contact the FREEFORMATER developer direct with your question about their product http://www.freeformatter.com/json-formatter.html at freeformatter@gmail.com
0 Me gusta
No aplicable
Never mind about converting to json format. That is actually arbitrary to finding the real solution here. I am writing a program to read a dxf file line by line and extract information about the object. For example, the X, Y, and Z coordinates of a mesh are given in a dxf file under "AcDSubDMesh" followed by the group codes with each coordinate. I am able to generate a point cloud with the coordinates of the mesh edge points however I cannot find any information about face connectivity in the dxf file. Where can I find this information?
I have attached a dxf file as a txt file.
0 Me gusta
No aplicable
I am starting to realize that there may be information of the point index plus the corresponding vertex index within the dxf file under "AcDbSubDMesh":
90
        3
 90
       60 (Possible point index?)
 90
        1 (Vertex index?)
 90
        0 (Vertex index?)
 90
        3 (Vertex index?)
 90
       60 (Face index?)
 90
        2
 90
        1
 90
        3
 90
       60
 90
        3
 90
        2
 90
        3
 90
       60
 90
        4
 90
        3
 90
        3
 90
       60
You may notice in there sphere mesh object that there are points at the bounding edges that connect with multiple faces. This may explain the repetition of the 60's. I took this snippet from the txt file attached earlier. Where can I get help for decoding a dxf file to such detail?
0 Me gusta
john.vellek
Hi @Anonymous,
It looks like you are on the right track.  Here is a DXF reference that might help you and another here
John Vellek
0 Me gusta
john.vellek
HI andre.vega3
I am checking back to see if my post helped you with your problem or if you need additional assistance or information. Please add a post with your results so other Forum users can benefit.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
0 Me gusta
