>> AutoCAD 2017 we have, and we save all .dwg files on 2010 file format.
It's not the best solution to save all drawing to old DWG formats!
Converts objects to old DWG formats AutoCAD has to convert that objects (so these dwg files can be opened to old AutoCAD's)
If you open such converted dwg files with AutoCAD 2017 the old geometries are again be converted to the new objects types.
That means save as well as open is slower (because of converting geometry types)
Always it's like puzzle, sometime opening such converted to old dwg formats opening such a file with newer AutoCAD might fail, hard to repair that.
My suggestion:
Save the drawing with the newest dwg format
If anyone needs an old dwg format, then use command _SAVEAS ... but do this only as a copy of the drawing,
- alfred -
Alfred NESWADBA
www.ish-solutions.at ...
blog.ish-solutions.at ...
LinkedIn ...
CDay 2025------------------------------------------------------------------------------------
(not an Autodesk consultant)
