Save as _QSAVE
Save as _QSAVE
Save as _QSAVE
Good afternoon,
I understand that when I want to save the project last time, before closing the file with the _QSAVE command and immediately after closing the file, AutoCad asks me to save the project again though I didn't make no one modifications with commands or views... Something does not go to AutoCAD 2018? Could it be a bug?
With 2017 version this didn't happen..
J.FOCHT
Hello @Anonymous,
Here is a nice post by @john.vellek that may help you out. There are some other thoughts in the post also. Hopefully @john.vellek's suggestion will solve your problem. If not it seems like it could be a bug in the system.
Thanks!
If this helps you then hit the LIKE button or mark as an ACCEPTED SOLUTION!
Thank You!
Jonathan Focht
I also have the same issue in c3d 18. This maybe happens, if you save a dwg and move afterwards your cursor or zoom into your drawing ... this will be saved in your cache, which can cause a request of ACAD to save your dwg again, when you try to quit.
BR
Michael
I'm not sure it's a cache problem ...
I tried to save and close the file with keyboard commands without moving the mouse but the problem remains
David
