Save as not working
Save as not working
Save as not working
Every time I go to File Save As nothing happens...the command on the bottom "_SAVEAS" is there and if I hit enter it'll ask if I want to replace an existing file.
I've tried FILEDIA and set to 1, but that hasn't helped.
imadHabash
would you restart your AutoCAD and try again (in more different CAD files).if the issue still appeared please show us an image of what you see?
Imad Habash
I've tried reinstalling AutoCad and repairing, but get the same error.
Here's a screenshot of AutoCad.
imadHabash
let's try this :
  • after you active Save As command.
  • press and hold Alt+Spacebar.
  • type letter ( M ) .
  • by keyboards arrows press for a while Left then Right, UP and Down.
some time the dialog existing some where out of the screen. we can call it by the way above.
Good Luck..
Imad Habash
Wow that worked!  You're amazing...thanks so much.
T H A N K  Y O U !!!!
