Anuncios
Same texture on one surface looks fine, but it's glitched on another.
No aplicable
After copying one drawing from another, some surfaces renders their materials/texures right, while others are messed up. Is there a easy way to fix it? I tried to search for this issue but I haven't found anything :cara_de_decepción:
In attached example you can see one surface that is ok (grass) and the rest nearby that are messed up. They are all NURBS on the same layer, same material, same properties. Just a random thing...
0 Me gusta
Responder
Soluciones aceptadas (1)
366 Vistas
3 Respuestas
Respuestas (3)
Alfred.NESWADBA
Solución aceptada
in the screenshot we see the effect, but we don't know to which image or objects we look at.
First at all ... is this a screenshot of the render window or to the AutoCAD graphic window with visual style "Realistic".
When you assign a material with texture you also need to assign the texture mapping coordinates .. have you done that? You can do that with command _MATERIALMAP and option "copY mapping to" to transfer mapping coordinates from an object that looks correct to another object.
Also interesting ... which version of AutoCAD are you using?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
No aplicable
Thank you sir, you did it agin (you helped me yesterday with high coordinates). You are my hero! :cara_con_una_leve_sonrisa: copY mapping to was the answer.
0 Me gusta
Alfred.NESWADBA
You are very welcome! - alfred -
Alfred NESWADBA
0 Me gusta
