Anuncios
Same problem installing everytime
No aplicable
I have previously posted for assistance on why my installion keeps failing. I have tried the solution suggested (to delete any prerequisites that have already been installed) but that has not worked. I have also tried eveything else suggested on the forums. It appears in the installation log everytime
Install Autodesk Material Library 2014 Failed Download Failed, Installation aborted, Result=1603
I have Windows 10 and I am looking to download AUTOCAD 2014 though I have also tried downloading the other versions (but I always get the same message).
I would really appreciate any help, thank you!
0 Me gusta
Responder
Soluciones aceptadas (2)
405 Vistas
3 Respuestas
Respuestas (3)
JDMather
1. As a student there is no reason for you to download 2014 which isn't supported on Win 10 when you can download 2017.
2. Forget about installation problem for now.
Let's verify download of the install files first.
Well - I have to leave for work right now, back in a while for instructions...
0 Me gusta
JDMather
Solución aceptada
OK, I am back....
Do not use Install Now
Do not use Download Manager.
Use the Browser Download (see image).
Make sure to get both files (while the first one is downloading - in the lower corner of your screen there should be a Download Progress bar.  Open that up and follow the progress as the second download did not start automatically for me.
Post screen capture similar to the image above showing the completed downloads of the compressed install files.
Emmsleys
Solución aceptada
@Anonymous,
Were you able to try the suggested steps that JDMATHER posted?
Fo additional information 2014 is not supported on a Windows 10 environment.
More on this topic you can read over this article.
Moving forward I would recommend trying to download and run AutoCAD 2016 or 2017 student version.
If you are still having an issue please post back in the forums I'd be happy to help. Emoticono feliz
Thanks.
Sarah Emmsley
Technical Support Specialist
0 Me gusta
