Same block references with different rotation all show 0 rotation in properties
I have a drawing on which I have multiple block references with different rotation.
Something has happened since placing the blocks and now if I select two blocks with seemingly different rotations, they still both show as 0 rotation.
If I copy a rotated block and paste it, it pastes with a different rotation (the block's default 0 rotation)
An additional problem I've encounted with the drawing is that when I copy a block, the hatch inside the block is brought to front, covering the outline. If I edit the block reference and send hatch to back, all the blocks are reset. HOWEVER they don't all reset to the block's default rotation, a seemingly random number of blocks, while also reset, instead show as rotated 180 degrees (while it says 0 in properties)
What's happening here?
