HI,
I'm in a Typical situation.
I have a drawing which referenced more than 15 drawings. I'm using Rtext to display the Xref names in drawing. However, there not enough space in drawing to display all reference names in a single column.
Please help me how to display the attached reference names in two columns using Rtext or any other available option.
Thanks in advance
Regards
Paper
Thanks for the image: there is no "column" feature in RTEXT, you need to create a second list adjacent the old one.
OR... looks like you need to make your list area taller and move it so it does not interfere with your drawing.
HI, Thanks for the response.
The drawing should fit in A1.
Above the References there are notes and below have the legend, key plan, and title box.
There is not enough space; Therefore I'm looking for an alternate solution with RText, Lisp or any other.
Regards
Paper
