rotation locked on property box
Message 1 of 16
im trying to rotate text using property box but i cannot toggle it
is there someone who can help me?, please
im a full blown newbie here, thank you for response
Replies (15)
Message 2 of 16
user181
Could be because the text justification is set to "fit". If you change it to center or any other justification you should be able to rotate it.
Message 3 of 16
chriscowgill7373
is the layer locked?  I use the dark interface, so I'm not seeing it look "greyed"
is it possible for you to take a screenshot of the full properties palette, not just the quick properties?  it might provide us with some additional information.  Option 2 is provide the drawing so we can click on the text and snoop around ourselves.
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2026 on Windows 11
Message 4 of 16
thank you very much, it will help me a lot in the future. 🙂
Message 5 of 16
Vuxvix
Hi!
I also have problem with Rotaion property. I have uploaded an example file. Thanks for all the support.
Message 6 of 16
chriscowgill7373
@Vuxvix wrote:
Hi!
Your issue is completely different, and would probably have been best served as a separate post.  How was the second piece of text created?  The only difference fundamentally between the two pieces in your file is the one that wont rotate has Xdata associated with it.  I would suggest removing the Xdata and see if that allows it to rotate.
Message 7 of 16
cadffm
I can explain what the issue is (a software BUG, you should start a supportcase with a link to this thread).
1. You have a TEXT, ANNOTATION = YES and MATCH ORIENTATION TO LAYOUT also YES
    This way you don't have access to Text rotation property (what is ok in this case)
2. Change the property ANNOTATIVE to NO
   Correct would be: Rotation is available again, but it isn't! Autocad doesn't delete the information about  MATCH ORIENTATION TO LAYOUT (YES),
   That is the bug!
Start a supportcase, send feedback, fight for all of us 🙂
3. You can fix it by hand this way:
    Set ANNOTATIVE to Yes, set MATCH ORIENTATION TO LAYOUT to NO, Set ANNOTATIVE back to NO.
Sebastian
Message 8 of 16
Vuxvix
Hi! @chriscowgill7373  @cadffm
First, Thank you for your support. Also forgive me for the weekend post, so I can only reply to your feedback today.
I can give a basic explanation of my problem situation:
- I received a drawing with a request to change the viewport on the layout (rotated 180 degrees).
-After editing the layout, I need to change the orientation of the text (Dim, Text, Block...)
-During the editing process I use a lot of lisp:
+ Rotation model scape: UCS, Snapang...
+Flip Dimension
+Rotation by base point, Rotation by center Object(2 lisp).
These are the lisp I think might be related to the problem. I compared with the drawing at first. And the text in the original drawing doesn't have this problem. It is a line of text with the content: "Rotation"
-I tried editing in CADffm way: the problem is fixed. Many thanks!
Message 9 of 16
Vuxvix
Part2 of lisp
Ps:I don't know where to start supportcase. Can you be more specific!?
Message 10 of 16
cadffm
>>"These are the lisp I think might be related to the problem."
So you understood nothing from my Answer?
Did you ever heard about "Annotation Scaling" "Annotation Feature"?
You can read about it in Your Help [F1] or use a search engine for related pages in www.
YT - Video sample
If you would check the properties of your Text before and after your Lisp, you can see the lisp function changes nothing,
the problem is present before (and after) lisp function.
As I wrote, some disabled the "Annotation" property, but AutoCAD still keeping the Information about 'Match orientation on Layout",
what.
Why do you think your Lisps has anything to do with it?
Check the text in the original file, it is the same, nothing to do with these lisp files.
>>"Support case"
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-c...
Sebastian
Message 11 of 16
Vuxvix
Hi!
I am using Annotative for drawings. Looks like I know a little about it too.
as for the lisp- functions I just stopped at using it.There are many lisp that change many system variables. So I'm guessing what's possible according to my thoughts.
As for the situation I mentioned. Really thanks for helping me solve the problem.
I can't find the support case entry. The interface of the site has changed a lot. i also tried searching it on google.
Have a good day
Message 12 of 16
cadffm
>"I am using Annotative for drawings. Looks like I know a little about it too."
Perfect (it is very hard to explain it to someone who isn't familiar with it)
You can select you annotation (and ex annotation) Text,MText,Attdef objects
and run this  AnnoPOoff
For hatch it isn't possible and for block you have to change the property inside the BEdit,
this tool works for unnested Text,MText,Attdefs and is just a sample code.
Attention, it works for non-annotation AND annotation Text,
select your objects first, then start AnnoPOoff.
In you case, you can use QSELECT to select non-annotation Texts
Sebastian
Message 13 of 16
Vuxvix
Hi!
You are really thoughtful. i did it manually and it was pretty fast too.
By the way, can you do lisp automatically layiso a layer and unlock the layer if the layer is locked. I couldn't find this content, and it seems pretty small to create a new topic 😄
Message 14 of 16
cadffm
>>" lisp automatically layiso a layer and unlock the layer if the layer is locked"
Everytime just ONE layer? In this case you don't need program,
simple menu macro is good enough.
^C^C^C_.LAYISO;\;_.-LAYER;_unl;$M=$(getvar,CLAYER);;
Sebastian
Message 15 of 16
Vuxvix
Hi!
the same way the layiso command works. Selected objects will be isolated (if the layer is locked, it will be unlocked). I tried your macro function, it works as expected for 1 layer, but for many layers it fails.
If this is a lisp function it will be easy for me to generate hotkey. Thanks
Message 16 of 16
vijays2u
Solution is so simple but the issue was too big. Than you sir
