rotating view of model 360 degrees in all axis's
pwickensPPZT6
pwickensPPZT6
I have noticed when rotating a model in model space, that there seems to be something stopping the full rotation of the model. In order to get a view I wanted, I had to physically rotate the model 90 degrees and then I was able to get the view I required. This seems to be in the software and was wondering if there are any other commands to get full 360 degree rotation of the model in all axis's. I have tried the 3D mouse but this has limitations depending on the visual style.
cadffm
>" when rotating a model"
HOW?
>" This seems to be in the software"
No limit known (for me), perhaps there is a limit for a specific way/command you are using - which way are you changing the view?
Sebastian
pwickensPPZT6
I use the shift + middle button on the mouse.
cadffm
ahh, the 3DOrbittransp(arent) command
I can
Use the continuous orbit and stop when it fits your needs: 3DCORBIT command [F1]
or use the usual command 3DORBIT, right click / contextmenu -> and use mode 2
Sorry, I don't hmow how to change the 3DORBITTRANSP behavior, but I guess you can't change it.
Sebastian
pwickensPPZT6
Thanks heaps.
The 3dcorbit command does the job I was looking for. And thanks for the tip with 3dorbit – changing to mode 2 works.
Really appreciate your assistance with this.
leeminardi
Also try 3dForbit.  I like the control it gives you.  Move your cursor outside the circle to rotate the view about an axis perpendcular to the screen or inside for horizonatl/vertical/skewed axes.
lee.minardi
