Rotating UCS view causes blocks to generate random objects
Basically when I rotate my view in the UCS to be along x/y AutoCAD thinks for a while then rotates it with all these circles generating on the screen. They are all associated with blocks in the drawing. Please see screen shots.
john.vellek
HI @Anonymous,
Have you tried toggling off Hardware Acceleration in your GRAPHICSCONFIG to see if the circles go away?
John Vellek
Yes they went away. But I'm assuming I am no longer using the graphics card?
john.vellek
Hi @Anonymous,
Turning of the Hardware Acceleration might not big a big factor depending on the type of drawing that you do. Can you attach a screenshot of your GRAPHICSCONFIG window? Also, please tell me your exact AutoCAD version (type ABOUT at the command line), Windows Build (type WINVER at the Windows command line), and then lastly, the make and model of your graphics card and driver version.
John Vellek
Sure,
GFX/Driver etc is shown in graphics properties.
Drew.
john.vellek
Hi @Anonymous,
There is a newer update to Windows update that you should look to install. There is also a much newer graphics driver (391.03) available.  You are also not utilizing DirectX 11 with AutoCAD. Please install this version and hopefully that should get your HA back up and running.
John Vellek
