Rotating Model Space
Message 1 of 21
Does anybody know what happen to the graphic that allowed you rotate the whole model space screen through 90° angles. Not the steering wheel, I seem to remember it has like a compass look to it, you could scroll around or go in 90° increments.
Replies (20)
Message 2 of 21
Patchy
COMPASS like this?
Message 3 of 21
NESW but for 2D? see attached graphic
Message 4 of 21
john.vellek
Hi @Anonymous,
Welcome to the Autodesk Community!
Perhaps you are looking for some of the tools found in the View>Viewport Tools ribbon. Or those found in the Navigation Bar?
John Vellek
Message 5 of 21
imadHabash
Hi and Welcome to AutoDesk Forum,
i suggest to turn ON your NAVVCUBE
Command: NAVVCUBE
Enter an option [ON/OFF/Settings] <OFF>: on
Imad Habash
Message 6 of 21
It looks like the picture but in 2D mode, you just click on arrow in top corner and around your model space goes through 90°
Message 7 of 21
Would it be because I am using LT 2012 used to full version?
Message 8 of 21
john.vellek
Hi @Anonymous,
In AutoCAD LT you will not see the NavCube as it is designed to handle UCS changes in 3D. Check out the Navigation bar though to see if it helps.
John Vellek
Message 9 of 21
Increments of 90 degrees would be done using the two arc-shaped arrows at the top-right of the viewcube and outside of the compass. Those only become visible when you hover over that area.
The good-ole orbit ball was handy for adjusting your view of model space as well. The orbit ball can be activated by using the Free Orbit command. I always thought the term Free Orbit should have been something else because the orbit ball allows the user to control his/her orbit very predictably.
Hope that's what you're looking for?
Anyone remember the old Viewpoint and Viewpoint Presets commands? Way back when I mastered them I thought it couldn't get any better but evolution brought so many other great tools!
Message 10 of 21
john.vellek
HI @Anonymous,
Is this what you are looking for?
I turned on the UCS icon and then rotated it.
John Vellek
Message 11 of 21
I have begun working on Autocad 2021. How do i turn the model space around in 90 degree increments?
I used to be able to do this easily on the 2017 version?
Message 12 of 21
Alfred.NESWADBA
Model-space can't be rotated, you can rotate the view (how you look to the model) using e.g. the viewcube or you can rotate the geometry using command _3DROTATE or _ROTATE3D
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 13 of 21
pendean
Community Legend
Community Legend
Same exact way from R2017 is used in R2021: so how id you do it back then?
Hint: DVIEW>Twist option or UCS rotating with PLAN set to Current UCS, or... see other suggestions.
Message 14 of 21
I have Autocad LT. So no 3d.
I have elevations drawn up around a central room. I have to keep on turning
the wheel so i can see each elevation the correct way.
There used to be a cube where i can rotate the view. It has disappeared on
Autocad 2021.
I need help!
Message 15 of 21
Alfred.NESWADBA
>> I have Autocad LT
AFAIK AutoCAD LT does not have the viewcube if that is what you are looking for.
- alfred -
Alfred NESWADBA
Message 16 of 21
I am sincerely confused.
My friend has the cube on the right hand corner of her screen and she has
the same version that i have. Autocad LT 2021.
All i want to do is rotate the screen in model space so I can access the
elevations.
I am sure it is just a click of a button
Message 17 of 21
beyoungjr
Greetings,
Lets first get you un-confused...
Your last few posts have changed from AutoCAD 2021 to AutoCAD LT 2021, on multiple posts.  That is going to force us to respond in ways that will surely confuse things because as you have also indicated, AutoCAD LT is not truly built for 3D work.
That said, you may manipulate views and your viewpoint.
Check this video for changing views of 3D models or projects within AutoCAD LT: https://www.youtube.com/watch?v=4J4okAOtFb8
Check this video for actually manipulating objects in 3D with AutoCAD LT: https://knowledge.autodesk.com/support/autocad-lt/learn-explore/caas/video/youtube/watch-v--ScCPnuN7...
In this video you will learn some new techniques but you'll also notice the handy toolbar that is vertically placed on the upper-right of your drawing area.  You should find some screen manipulation tools there.
Check this Autodesk topic: https://knowledge.autodesk.com/support/autocad-lt/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/Au...
This information will show you how to change your viewpoint of your modle space drawing environment.
You might also consider sharing your drawing file so that we can assess the content and how we might navigate around to see different perspectives.
Cheers,
Blaine
Blaine Young
Senior Engineering Technician, US Army
Message 18 of 21
Alfred.NESWADBA
Can your friend please start command _ABOUT, create a screenshot of this command and you show this screenshot here?
- alfred -
Alfred NESWADBA
Message 19 of 21
I’m sorry to confuse you again. But I am working with autocad LT 2021. Just
looking to rotate screen in 90 degrees. Not to get a 3D view
Message 20 of 21
beyoungjr
Here is your solution...
https://forums.autodesk.com/t5/autocad-lt-forum/rotate-view-in-model-space/td-p/8936514
Here is the knowledge base article on the UCS command.
https://knowledge.autodesk.com/support/autocad-lt/learn-explore/caas/CloudHelp/cloudhelp/2021/ENU/Au...
Hope that hits the mark?
Cheers,
Blaine
Blaine Young
