Rotate Dimension Grip Stretch to End Point
jayhar
jayhar
Have any options to Rotate Dimension Grip Stretch to End Point ????
watch this video here
All Mtext are justify Top right, so i can easy select grip and move to Xline, Leader can also easy select grip and move to Xline. But Rotate Dimension cannot stretch to xline using grip, because grip is not in End point. If can remove Text from Rotate Dimension ??? or any autocad lisp routines
Thanks & Regards,
JAYHAR.M.J
Asst: Team Leader
CICON Rebar Solutions Pvt. Ltd.
DD Trade Tower, Kaloor-Kadavanthara Road,
Kaloor, Ernakulam, Kerala,India - 682017
E-mail : jayharcicon@gmail.com Mob : +91-9961032444
Issued by Autodesk
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
0 Me gusta
Responder
Soluciones aceptadas (1)
1.880 Vistas
13 Respuestas
Respuestas (13)
natasha.l
Hello @jayhar
Thank you for posting.
I suggest trying to review your Grip Snap & try the AMPOWERSNAP command (Filters>Uncheck Dimensions).
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
0 Me gusta
Alfred.NESWADBA
Hi @natasha.l
This is not a command of AutoCAD, therefor you need AutoCAD Mechanical.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
0 Me gusta
Alfred.NESWADBA
Hi @jayhar,
Can you please upload the dwg-file?
I'm not sure to understand the question correctly.
- alfr3e4d
Alfred NESWADBA
0 Me gusta
Kent1Cooper
What part  of the Dimension is that?  An extension line?  The dimension line?  Part of a custom arrowhead?  Are there parts that are suppressed, such as an extension or dimension line, or the arrowhead?  Is that grip at the place where something suppressed crosses a part that is not suppressed?
You can "remove" the text by double-clicking on it and "editing" it to be a single space, or picking in the Text override slot in the Properties palette and putting a single space in there.  [More than one  space ends up making a gap in the dimension line.]
Kent Cooper, AIA
0 Me gusta
jayhar
Hi @Alfred.NESWADBA
1. All Mtext are justify Top right, so i can easy select grip and move to Vertical Xline.
2. Leader can also easy select grip and move to Vertical Xline.
3. But Rotate Dimension cannot stretch to Vertical Xline using grip (Rotate Dimension is Text Override using space bar gap)
watch this video & dwg is attached
Mtext, Leader & Dimension are move to Vertical Xline for drawing in good order.
if you did not understand watch this video also
Jayhar.M.J
0 Me gusta
jayhar
Hi @Kent1Cooper
<<<<<<What part of the Dimension is that? An extension line? The dimension line? Part of a custom arrowhead? Are there parts that are suppressed, such as an extension or dimension line, or the arrowhead? Is that grip at the place where something suppressed crosses a part that is not suppressed?>>>>>
Please see the attachments is this post
<<<<<You can "remove" the text by double-clicking on it and "editing" it to be a single space, or picking in the Text override slot in the Properties palette and putting a single space in there. [More than one space ends up making a gap in the dimension line.]>>>>>
This method is using in all project, that i know.
Jayhar.M.J
0 Me gusta
S.Faris
"1. All Mtext are justify Top right, so i can easy select grip and move to Vertical Xline."
You can use TEXTALIGN to do that job all at once right?
If you are using dimensions only for graphical representation and not for dimesioning purpose, Why not make a dynamic block to suit your needs? This will make your task much simpler and will be more flexible.
SALMANUL FARIS
0 Me gusta
S.Faris
Here is a not so fully polished sample Block.
  1. Prepared using an exploded Dimension
  2. Prepared using an embedded Dimension (So that Dimension style changes will reflect Automatically)
SALMANUL FARIS
0 Me gusta
jayhar
Hi @S.Faris
I requesting you to read this post once again.
<<<<< If you are using dimensions only for graphical representation and not for dimension purpose, Why not make a dynamic block to suit your needs?>>>>>
Good Question
<<<<Here is a not so fully polished sample Block.
Prepared using an exploded Dimension Prepared using an embedded Dimension (So that Dimension style changes will reflect Automatically) >>>>>
watch this video also.
Your block can Stretch only one direction, Ok another wise its good idea make a dynamic block
Jayhar.M.J
0 Me gusta
Alfred.NESWADBA
Thank you, that made it more clear.
If you move the text of a dimension then the dim-line is made longer then the text, I guess to make sure all text has a dim-line under itself. Sorry to not know if there is a parameter for that in the dimension-style, at least I have not found one.
I would not know a workaround (as long as you need to do this with dimensions) than measure the length of the overshoot (which is 45 in your objects (not tested all)) and move the text-grip point back by that length.
- alfred -
Alfred NESWADBA
S.Faris
Try making TEXT OFFSET "0"
SALMANUL FARIS
0 Me gusta
jayhar
Solución aceptada
Thanks All
Solution Founded
Select Rotate Dimension in properties Text offset <0> Grip will be End Point.
here the video
Jayhar.M.J
0 Me gusta
Alfred.NESWADBA
That's interesting, because TEXTOFFSET is the distance perpendicular to the dimension line :cara_guiñando_un_ojo:
>>>here<<< it's shown with that sketch:
But good to know it works for you.
- alfred -
Alfred NESWADBA
0 Me gusta
